TwinTurbo.NET: Nissan 300ZX forum - I suggest as a rule of thumb anything over a stage 3
Subject I suggest as a rule of thumb anything over a stage 3
Posted by The Devils Z on June 11, 2008 at 1:26 PM
  This message has been viewed 183 times.
In Reply To at what HP level, or psi, is it recommended to ... posted by itsghoZt on June 10, 2008 at 11:09 AM
Message chip which is about 13psi. The reason has nothing to do with power. With BOV, you in between shifts the boost will rise quicker to the previous level prior to the shift. What you are doing is increasing boost response artificially because the turbo doesn't spin in the opposite direction as much ( I forget the physical process and I don't feel like researching it ) because of the air that is being vented.
This also minimizes the shock to the turbo from elevated psi levels.
=============Sig begins here================
The Devils Z.com
The Devils Z Pic
666 rwhp dyno
The Demon Z pic (in progress)
View Me! Disclaimer : Not Safe For Work !
